kramer5150
Curious... Has anyone done a detailed comparison between OP and smooth reflector finishes? I am looking for Lux/Lumen measured comparisons, as well as outdoor beamshots.
thanks
thanks
I'm a comparative newcomer here and certainly I've never seen one........ but from what I've seen, there's a good deal of variation among OP reflectors' finishes. Some are a lot more wrinkly than others. And I think there's some variation among smooth finishes, too, though obviously much less. If you're after a quantitative comparison wouldn't it have to be limited to that particular OP reflector? Or maybe you could count on a given manufacturer always using the same process and therefore getting the same results.....Curious... Has anyone done a detailed comparison between OP and smooth reflector finishes? I am looking for Lux/Lumen measured comparisons, as well as outdoor beamshots.
thanks
thanks
All things equal, the smooth reflector will technically be "more efficient."
In reality, it depends how you want your subject illuminated. If an OP reflector provides more useful light for the task, then it's more efficient.
I think this would be true if you changed the last word to "effective".
"Efficient" is normally used to compare the ratios or percentages of output to input. One engine is more efficient if more of its fuel is delivered as useful work and less as heat, noise, distortion etc.
In comparing reflectors, I suppose one would be comparing the actual light output of one reflector against another from the same light source. I don't think "efficient" takes the purpose or the usefulness into account.
I have a small test...follow the link in my sig and search the file for the smooth and Op reflector measuremnts of the DX1447 module
These days I have both smooth and OP reflectors for my modules and if it was not that time comsuming I would already made measurements of the Derrelight 3SM2 module with both reflectors and 2or3 batts
