Hi
I got empty shell from Peak so I had to fill it up.
Driver parts are from cheap 5 led bike light with changed inductor.
I had to solder parts direct to each other, inductor,diode, capasitor and transistor.
I had to dremel some metal from sides of the led because it has small positive contacts on sides too
It has small brass heatsink glued to leds bottom.
Current draw is 390mA from fresh ni-mh AAA
Peak on left, Arc AAA with BS-led on right
As you can see it is all flood.
I like how brass reflector warms beam color.
Juha
Juha
