liquidsunshine
Hi everyone,
I recently decided to buy four H30-Q5 from Zebralight. The following were my considerations regarding batteries before that decision:
Primaries have become quite cheap, but I still consider it a waste to run a light on primaries that you use a lot, so primaries are not a real option for me other than as backup.
I personally do not think current affordable 123-chargers are safe enough to be fully trusted to charge an unprotected cell, and also I don't want a cell to be destroyed by deep discharge - so unprotected 123's are not an option for me either.
That left me with protected rechargeable 123's.
Zebralight advertises this light as capable of runing on rechargeable 123's, but they don't specify whether that includes protected cells or not.
In a different thread here I read that people are using protected rechargeable 123 cells with their H30-Q5. Based on that I decided to buy this light - only to find out that unfortunately, none of my lights is long enough for protected cells. That basically means that I have a wonderful light that I can't run in an acceptable way.
HUGE DISAPPOINTMENT!
Why the hell did Zebralight not simply make the threaded part of the body 1.5 mm or so longer to accomodate protected cells?? It's such a great light, and if it's capable of running on rechargeable cells as they claim, then that's a HUGE oversight!
Guys, guys, I don't know what to say - I really love the whole light, but this one fact sort of destroys the whole point of having it for me.
Are some of the H30-Q5 shorter than others? Are my protected cells longer than other protected cells? I am using Ultrafire and Trustfire (grey).
Anyone please advise me which protected cells will fit.
Also, can anyone confirm for sure that this light will not be destroyed if run on a rechargeable 123 fresh from the charger?
I'm thinking of a crude modification: Putting a small ring of metal into the tail cap, bridging the distance between the flat golden tailcap contact ring and the end of the body thread. If the elctronics are ok with up to 4.2 volts or so, that might be a mod to consider - even though it would destroy the "lockout" feature, because the ring would rattle around inside the lamp, could tilt, and bridge the gap creted by loosening the tailcap a bit - another disappointment, as the lockout feature is very important to me.
Seriously, that's just sooooo disappointing. If there's no solution for this I'll have to try and return them to Zebralight, hoping that they'll take them.
Man, what a bummer.
Matt
PS: I'm only talking of 3.6V cells here. The 3.0V cells are out of the question for me, for various reasons.
Man, what a bummer.
Matt
