I recently purchased a Dereelight DBS 3SD. I notice if I look at the lense from an angle it looks dirty on the inside, kind of dusty and opaque, almost greasy. Its definitely not on the outside of the lense. There are some dust flecks on the reflector also. I took the head off the light and found that I could not easily twist out the reflector to access the glass, I did not want to force it. I assume the reflector is threaded into the head of the torch?
Also what would be the safest way to clean the lens with out damaging the coating? isopropanol and lens tissue?
Thanks in advance
Thanks in advance
