Re: cree Q5 @ 1200ma with 2 x 18650's
Thanks for the advice about using resistors, I will have to re-consider this as I can now see its going to be quite inefficient.
A parrallel setup is not an option, I should have explained more about this project -
I have an old Tiablo A9 without a driver, and a new Tiablo A9 coming in the post. I need 2 seperate light options, one with a Cree red XR-C and the other with a Cree XR-E Q5, plus I require full regulation with 18650's and long runtime. I can achieve this easily as I will have 2 LED/driver units
This is my solution - I have cut down a spare tail cap to use as a treaded socket and compression fitted it permantly to one battery tube, the socket then screws onto the the other battery tube, thus making a 2 x 18650 Tiablo A9 (fully regulated)
Also I can unscrew a battery tube & replace with the tail cap to revert it back to the standard A9 if ever needed. I can also change over the LED/driver units to select the red or white option]
As an option I could use the red XR-C and with one 18650, the red XR-c will have a lower forward.
I think I should go to the trouble of fitting an aftermarket driver in the 'empty' LED unit so that both LED units have their own circuit.
Here's another option I though of this morning, & I think it's qiute interesting -
I have a few spare Dereelight pills, I think I can machine out the Tiablo LED housing to fit in a Dereelight pill, it may need a brass shim to ensure good thermal & elictrical contact and should'nt be too hard to make, any thoughts??
I'll post some pics once I decide which way to go & have made a start
thanks
