Northern Lights
Withdrawn-RECHARGEABLE 1.5 D P7, Modes, Electronic GID & more
withdrawn from sale-RECHARGEABLE 1.5 D P7, Modes, Electronic GID & more UNIQUE than my others.
Check the features available in these lights. Comparable pricing, more features in one package than the others.
1.5 D P7, Modes, Charging Jack, Electronic GID & more
Look below; in brief longer run times with premium batteries, best reflector, it is rechargeable and with improved features.
1 Sputtered reflectors and OEM smooth reflectors do not put out the light like this premium reflector
2 You may have the sputtered and OEM if you ask, by why bother, they are inferior to the metal LOP supplied.
3 AW cells are 3300 mAh and run over an hour; more than the little 18650s which are a maximum of 2400 mAh no matter what they say, Chinese Batteries are usually over rated
4 Rechargeable Charging Jack, charge the light with a cord, who else has this?
5 Coated lens (window) transmits more light
6 Glow in Dark (GID) switch cover that is powered by an always-on 5mm LED in the switch on low power consumption!
7 Switch stroke is shortened for smooth operation and feel.
8 Pinned heat sink prevents twisting of wires when head is turned
9 H22A sink is solid and handles the long runs
10 Tail cap resistance is nominal because of braid jumper modification
11 Special care has been taken to insulate and/or strengthen solder connections to board and Jack and to insulate exposed connections.
12 D2DIM allows for tactical straight OFF/ON programming. It is not necessary to cycle through modes to operate the light features. The light can be shipped to you programmed with your choice of program features.
13 Tail cap resistance is nominal because of braid jumper modification
MY DESIGN IS LIKE THIS:
3D MagLite Cut to about 1.5 D, silver natural aluminum finish.
Bored Channels to accommodate side by side 18 mm or less diameter batteries
Seoul Semi Conductor P7 C bin LED from KD, CSXOI
H22A new style heat sink setting on thermal grease
Heat sink is pinned to prevent spinning when assembled and allows take down.
D2DIM PWM (taskled.com) mode control with two User Interfaces programmable Modes, from on/off to variable and stepping output, your choice by program
Monetary only short stroke modified switch
GID switch cover that is powered by an always on 5mm LED in the switch on low powerconsumption!
Chaging Jack, any lithium 3.6V charger can be jumped to charge this light
Sleeved for C cell
AW C-cell protected Lithium-ion, 26540, 3300 mAh battery- WAY MORE RUN TIME THAN itty bitty 18650 batteries!
Polished smooth tail cap
C-cell spring retained in D cap with copper braid jumpers to reduce resistance
Three reflectors, if you ask for the others, OEM smooth and sputtered are inferior to…!
KD 52 mm LOP, aluminum reflector supplied standard supplied, the best for P7
KD coated clear lens
D2DIM links: http://www.taskled.com/leds/d2dim.pdf and Dichotomous Chart
EASY PROGRAM CHART AT THIS LINK http://img370.imageshack.us/img370/9540/clipboard01ht4.
Here is the thread on this light:
I am supplying three reflectors if you really want them, the first two are useless, OEM smooth, OEM sputtered and the KD P7 reflector. A jack plug is included.
Buyer pays shipping, shipped US Postal Service, http://www.USPS.com ,and mailing insurance. Shipping is done on receipt of payment, PayPal or certified check or money order. I will honor the first "I'll take it" without conditions posted in the thread. I check CPF in the night, Mountain Standard Time, UTC/GMT -7 hours. Private Message the specific details please.
This is a custom modified light; Consider since it was not made for commercial sale then it is made with used parts. All the components are modified and are not in the original condition and configuration of the manufacturer. While these batteries are considered a "safe" the buyer assumes all risks and responsibility to use this light safely and appropriately. This is a private sale and there is no warranty or guarantee. By making this purchase the buyer certifies they are at least 18 years of age and assume all risks and responsibility to use this light and parts safely and appropriately and accepts the light and parts in an "as is" condition..
WHAT IS BETTER OR UNIQUE FROM OTHER 1.5D P7 BUILDS??
Sleeved for C cell
$255 USD
Quick summary:
More than just off and on for same price class
Compact size, proven commercial (not home made) reflectors
P7 brightest bin, one of the brightest single LED available!
Coated optics for maximum output
Rechargeable light, "in the light" recharging
Electronic Glow in the Dark locator in the switch.
User programable Modes, 3 User Interface programs D2DIM, www.taskled.com
Safe Protected lithium power, long steady output runtime superior to 18650s
Excellent construction features mechanical and electronic
Quick summary:
