Seppo_Vesala
Hi,
I´m a cop living in Finland. Since there seem to be some knowledgeable people writing in this forum, I was hoping that I would get some good advise on buying a new tactical flashlight for streetwork. My current flashlight is Streamlight Scorpion. However, I´m not satisfied with it mainly because of three reasons: It is not bright enough, it can be scwitched on accidentally (which runs down the battery and burns a hole into the lens), and it doesn´t have a proper momentary switch.
The flashlight should have the following features (or as many of them as possible):
-be about the same size (4,9" long) and weight (4,4 ounces) as Scorpion
-be water and shock resistant
-have a dark, non-reflective surface
-have a tail-cap end switch
-have a "dead-man" -type momentary switch (which burns only as long as the switch is pressed), and a separate constant switch (for example, press for momentary, twist for constant; like Sure-Fire flashlights have)
-be bright enough (at least 15,000 candelas and/or 50 lumens; the more the better)
-have a smooth beam with no irregularities or dark spots
-the batteries should run for at least 1 hour
-the cost of operating should be low (no expensive spare parts, for example)
-the price should be reasonable (preferably less than $100)
additionally, the following features would be nice:
-it should have an adjustable light beam (or holographic diffuser)
-it would be nice if it had a similar rubber sleeve than SureFire lights have (to allow SureFire/Rogers firing technique)
-it should be shaped so it won´t roll on the ground if dropped
The material is not an issue, as long the flashlight is sturdy enough. Also, the power source is of little importance, but if the flashlight is rechargeable, it would be nice if the battery could be recharged when removed from the flashlight, and if it runs on batteries, it should accept regular batteries (no special battieries that are available only from the manufacturer).
I hope some of you could help me out on this one. Also, some first-hand experiences on flashlight fitting these criteria would be great.
Thanks!
<font color="black"> </font> <font color="black"> </font> <font color="black"> </font>
Thanks!
