The upcoming Surefire UA2 Optimus, expensive but focusable.
Ok, so there's not quite a big choice so i'll make my criteria a little bit tighter My girlfriend asked me what do i want(actually she asked me which light:laughing::devil: do i want) for holiday present. I was completelly shocked but soon started to look around for some little bright *******s I would like to have a small- sized LED torch, preferably with 1 or maybe two AA cells, optionally with adjustable focus. I currently use a LED lenser P5 but i'm looking forward having a little bit stronger light. But in the same breath, i must admitt, it's focusing system is absolutly great! Waht lights do u suggest? I was thinking about a MiniMag 2AA with 100 lumed terralux upgrade, since the torch is so cheap here in slovenia? Are there better alternatives for about 50$ in USA shops or 50€ in Europe? Another wish is a LED lenser p7 with 170 lumens (unregulated) which is 70€ in local stores and quite unreachable. Any suggestions, advices, and links are highly welcomed!
The LED Lensers have the best focusing feature of any light on the market, but they all run direct drive and use multiple AAA/AA cells. They are also quite a bit more expensive than they should be in my opinion. I was considering buying a P14, but I couldn't justify spending nearly $100 on a single stage light that has zero regulation.
1. It has 225lm on Li-Ion as well.
2. It has donut hole at wide beam.
3. It's discontinued.
The focus mechanism and LED used in most of these lights is exactly the same, so the results will be the same, with only a modest variation in what distances a donut hole appears.
It's not single stage!!! P14 has 2,5 modes D). Low (15%), high (100% - 130 lumens) and momentary turbo (130% - 170lm). Zero regulation means there's no circuit board and brightness drops gradually. I agree, there's no special circuit but runtime graph is quite flat (that's the nature of Ni-MH and lithium batteries). No driver may be an advantage - nothing to fry/broke!
Fenix E20 is focusable indeed but on flood focus beam is ugly.
