EAGTAC
Results 1 to 12 of 12
Thread: Led Lenser P7 advertized hours ????
    Unenlightened
    Nov 2008
    Default Led Lenser P7 advertized hours ????
    Can someone tell me what the duration of running the Led Lenser P7 is?
    Here the company says 120 hours:
    http://www.zweibrueder.com/ENG/produ...e/p7.php?id=p7
    Here the company says 130 hours:
    http://www.ledlenserusa.com/product_...?modelNum=8407
    And I finally buy one, and the box says 50 hours!!!
    now I know it depends on brightness settings, but come on!!
    And I think there were some postings on this website saying it was TWO hours ?!
    Feels like that magic trick with the 3 cups and the one ball....
    Dec 2006
    Montreal, Canada
    Default Re: Led Lenser P7 advertized hours ????
    You'll have to learn to see through company's BS. Even 50 hours is grossly over estimation. The claimed runtime is probably keep running till emitter stop even glowing, which is essentially useless information.
    You'll get 2 hours of decent light, which is typical of most lights. Anything over 10 hours is either running off big batteries or using a very efficient or underdriven LED.
    DX Fauxton, Terralux Minimag w/ Acrylic Sphere, DX Cree R2 keychain, DX Cree R2 2xRCR, SureFire 6P (soon to be modded), Mag 2D (soon to be modded)
    Flashaholic* M@elstrom's Avatar
    Oct 2007
    Sunraysia, Australia
    Now that's ironic isn't it? a flashlight called a P7 that doesn't use the P7 emitter
    My modest collection HERE & 55w HID spotlight project HERE
    Quote Originally Posted by jzmtl View Post
    +1, I think they had a candle sitting next to the light when they tested it
    Take care
    Oct 2008
    Portugal
    Quote Originally Posted by M@elstrom View Post
    LOL yes!
    Actually when I bought the P7 I didnt knew what a P7 led was... so no problem , but the name can lead to some misunderstanding.
    About the runtime mine also says 50h in the box... but with 1000mah nimh you will get more less 2h to 50% wich is very good, and this light has probably the best throw for the size.
    I EDC mine in my computer pack and its always great to get so much power out of such a small light. A bit heavy but thats the 4 AAA design
    If you had already tested the throw in it try it also with the lense 1 to 2mm open.. it will throw the same and produce more light
    Regards,
    Artur
    Oct 2007
    Considering that a good AAA Alkaline has a capacity 1000~1200mAh @ 1.5v I don't see how you'd get much more than 2~3 hours runtime MAX
    Probably it's a translation bug, hours instead of minutes.
    I know everyone on here makes fun of their ridiculous runtime estimations, but has anyone actually done a runtime test on the low mode? I've only seen pictures, but it does seem quite a bit less bright than high. It could in fact run 50 hours?
    Oct 2008
    Portugal
    In low its ate 15%... so if you get 2h in max... making some simple calcs...it will do more less 15h?
    Artur
    Dec 2006
    Montreal, Canada
    It has that capacity at 25 mA current draw, only 700 at 100 mA, and down to 400 at 400 mA.
    *Flashaholic* Marduke's Avatar
    Jun 2007
    Huntsville, AL
    Quote Originally Posted by phantom23 View Post
    Then they have neglected to "fix it" for many years now.
