kosPap
well after scrwin up with the ebzel I found out that you can easily unscrew the bezel some and get a wider beam. Add an O-ring between bezel and body to create some thread locking tension and you are GTG.
Here is how it is made:
NOTIVE threads are not very long and you are using valuable thread area with this method!
and here are the comparison beamshots (at 1 meter)
-2 stops
I used a Surefire C2 body O-ring for maximum effect (measures 19mm inner diameter by 2mm thick). Alternatively the 20mmx1.5mm O-rings taht Dx sells are inbetween effects...
Enjoy, Kostas
-2 stops
Enjoy, Kostas
