Jetbeam
Page 1 of 4 1234 LastLast
Results 1 to 30 of 109
Thread: ●=●=● Tasklight Two -- A CR2 worklight/flashlight ●=●=●
    Dec 2003
    western Massachusetts
    Default ●=●=● Tasklight Two -- A CR2 worklight/flashlight ●=●=●
    SOLD OUT: Tasklight Two
    Sorry, but these are no longer available.
    In stock for immediate delivery.
    This was originally made as a custom light for jch79, who wanted a multi-level light to use while soldering, or while assembling lights. Now, I've recreated it with a few variations and produced a small run of 50 pieces.
    SPECS:
    • Twisty--twist the head to turn it on or off. Battery rattle is controlled with silicone washers (installed).
    • A 1/4" x 20 tpi socket is built into the tail of the light for use with standard tripod screws, or adjustable arms.
    • Mini FluPIC driver provides three brightness levels, plus two other modes--one for setting one of the brightness levels and the other is null.
    • Powered by either a RCR2 or a primary CR2. The light is shipped with a primary battery installed. For rechargeable CR2's, I recommend AW's offerings.
    • The lens is a 1.5mm mineral glass lens.
    • The Khatod reflector is 20mm in diameter and stippled.
    • The LED is a Seoul P4, bin U2SV0H
    • Length is 2.47", diameter is .80" and the weight is 1.4 ounces.
    • Body is 7075AL that has been electroless nickel plated.
    • Body styling is cut knurling that was polished prior to EN plating, so it is very smooth to the touch.
    Some photos:
    Price: $160.00, delivered worldwide.
    CONUS shipping includes Delivery Confirmation, but no insurance. Please contact me if you need insurance, or other forms of delivery.
    PayPal cash to: paycashpal (at) photonfanatic.com
    or
    PayPal credit card to: fanatic (at) photonfanatic.com
    Thanks.
    Mini FluPIC Modes
    The Mini FluPIC has 5 modes. Each mode is arrived at by turning the light on that many times. For example, to get to mode 1, just turn the
    light on. To get to mode 3, turn the light on-off-on-off-on (i.e. 3rd on = mode 3).
    The PIC does have memory--it will restart in whichever mode that you last used, i.e., modes 1 through 3.
    Mode 1 is preset to burst mode (approx 650 ma)
    Mode 2 is user settable to any of about 10 different levels
    Mode 3 is preset to low
    Mode 4 is null/blank/not used
    Mode 5 is used to set the level of Mode 2 - turn the light on 5 times (no light will show for the 4th on). The light level will ramp all the
    way up in steps and then ramp down. When the brightness is at the level you want to set for Mode 2, turn the light off and leave it off
    for a couple of seconds. Mode 2 is now set at the level it was when you turned the light off.
    Additional Notes:
    If you go into Mode 4 and just stay there, the PIC will then move into burst mode after a couple of seconds.
    The mini FluPIC will only start in one of the first three modes--if the last adjustment you did was to set the user settable level, i.e., Mode 2,
    then the light will resume in Mode 1.
    PhotonFanatic—fanatic@photonfanatic.com
    CPF Custom Builders and Modders
    My Blog
    darkzero's Avatar
    Oct 2003
    SoCal
    Default Re: ●=●=● Tasklight Two -- A CR2 worklight/flashlight ●=●=●
    Wow, that's beautiful!
    -Will-
    Sorry, I have retired from flashlight modding & I do not make custom flashlights. Thank you for your understanding.
    My Mod Archive
    Flashaholic* olrac's Avatar
    Aug 2007
    Lake Zurich, Illinois, USA
    Fred you are a Renoir of lumenosity!
    Dec 2003
    Thanks, guys!
    My Blog
    Dec 2003
    TTT
    My Blog
    Jun 2006
    TN
    Looks teriffic So so tempted, but have spent too much lately on lights. maybe after christmas(sigh).
    does the flupic put out the same levels on 3.0 and 3.7v? traditionally the flupic functions much brighter on 3.7v. I assume the high(burst) level is meant for short runs to avoid shortening the useful life of the seoul?
    Thanks Fred for the nice work!
    Dec 2003
    I don't think that 650mA to the P4 will shorten the life of it at all.
    Yes, I believe the rechargeable 123 will yield slightly more mA to the emitter.
    My Blog
    Dec 2003
    I take it that the economy and job situation are much worse than I thought--so I've dropped the price a bit.
    Hey, if they don't sell, then some folks are getting real nice presents this year.
    My Blog
    Dec 2003
    bump!
    My Blog
    Dec 2003
    ttt
    My Blog
    **Do Not Feed The Vegan**
    jch79's Avatar
    On the asphalt.
    Let's see how it stacks up against the original!
    BTW, this light has been AMAZING. When I'm not using it in my workstation for soldering, it makes an awesome pocket light, due to how small and lightweight it is.
    Thanks Fred!
    john
    Mar 2004
    Newfoundland Canada
    i will take one pp in the am
    Dec 2003
    BTW, the body of this light is machined from 7075 aluminum, not that cheap 6061AL.
    My Blog
    Mar 2004
    Newfoundland Canada
    here is my stimulus package. PP sent
    Dec 2003
    Quote Originally Posted by Arcoholic View Post
    Merci! Package was mailed today.
    My Blog
    Jun 2002
    Austin, TX
    I'll show my ignorance and ask... what's the flexy, stalky thing that screws into the back of the light in the pic and what size are the threads? tripod size? And whats the half domey, bulby thing to the right?
    .: I spent most of my money on women and toys. The rest I just wasted :.
    Dec 2003
    Quote Originally Posted by fasteddie View Post
    Ed,
    The threads in the bottom of of the Tasklight Two are, indeed, standard tripod socket threads, i.e., 1/4" x 20 tpi (threads per inch).
    The black flexible stalk is just that--an articulating metal tube that is covered with heat shrink tubing, both ends have 1/4"-20tpi male threads on them. Obviously one end is inserted into the Tasklight, and the other into a heavyweight metal base, or similar fixed platform.
    The other 'half domey, bulby thing' is a magnifying glass, I believe.
    My Blog
    Jun 2002
    Austin, TX
    Thanks. I really like the combo of the flashlight on the articulated arm stand. The machining on the outside of the light looks terrific. I wish it had a lanyard or keychain attachment in addition to the tripod socket. Anything in the works?
    To follow up:
    Where does one find those articulated arm things?
    This is the domey thing I was asking about. Not just the dome part, but what's under it. Doesnt look like a tasklight.
    Quote Originally Posted by PhotonFanatic View Post
    Ed,
    Dec 2003
    Ed,
    The articulating arms are from this company.
    Yeah, I've been thinking of making a split ring adapter to fit the Tasklight Two. Probably would be cheapest in AL, although an anodized Ti version might be nice.
    And that domed thingy is a Luce de Notte.
    My Blog
    Sweet little light Fred
    Flashaholic* Eric242's Avatar
    Jul 2006
    [-Mad in Germany-]
    How did I miss this thread with such a beautifull light??
    I´ll take one Fred. I´ll send cash paypal as soon as I received a some cash - should be before christmas.
    Eric
    Move Through The Light .... With Caution
    My Collection.......... just click on me if interested
    Jul 2006
    [-Mad in Germany-]
    Eric
    Dec 2003
    TTT
    My Blog
    nfetterly's Avatar
    Oct 2008
    Cincinnati area, but lots of travel
    Beautiful light. A split ring adapter (aluminum would be okay) would really put it over the top for me & I would buy it - I don't need it primarily as a work light, more as a carry light.
    Of course I bought my last flashlight (for a while) about 3 flashlights ago....
    Neale
    jch79's Avatar
    On the asphalt.
    Quote Originally Posted by nfetterly View Post
    Search for part #90117A535 on www.mcmaster.com (couldn't figure out how to link to that part) - it's a Drilled Head Socket Head Cap Screw - the hole is only about 1.5mm wide, but you could widen it pretty easily if it didn't fit. Seems like it'd work!
    john
    Aug 2007
    If you check out the Sgt. Burkett 18650 thread on the CPFM
    http://www.cpfmarketplace.com/mp/sho...d.php?t=184071
    he sells a split ring adapter that would fit this light. He calls it a "butt" and it's $2.00.
    Here's a link to a picture as well
    http://etendue.cafe24.com/file_data/...kett%20pal.jpg
    jch79's Avatar
    On the asphalt.
    Quote Originally Posted by olrac View Post
    Perfect! Thanks for the link!
    For those of you who are too lazy to hit the link:
    EDIT: Forgot that Berkeley Point has similar items, except with a swivel.
    http://www.berkeleypoint.com/product...wivelring.html
    john
    kaichu dento's Avatar
    Apr 2008
    大和/Alyeska
    Okay, here's the exact post in which he first mentions this part!
    http://www.cpfmarketplace.com/mp/showpost.php?p=2222026&postcount=136
    Marduke - Solitaire...I've seen matches which are brighter AND have a longer runtime. 光陰矢の如し
    Dec 2003
    Thanks, guys. Looks as though either of those will work just fine--now I can go build some Ti lights, rather than worrying about making some sort of split ring attachment device.
    My Blog
    darkzero's Avatar
    Oct 2003
    SoCal
    Quote Originally Posted by jch79 View Post
    john
    These are pretty strong. I purchased one of these from the Shoppe for $6. Looks like they're out of stock but perhaps they might have more stashed away & could put some up.
    -Will-
    My Mod Archive
