Alright, hopefully this will be the last plea for assistance, I just want to check my math before I pull the trigger.
In building a prototype of the wall sconces, I need to figure out just how much light is appropriate. So I reason a constant voltage driver will allow me to vary current across the one LED I'm running with use of various resistors and find a happy amount of lumens.
My question is thus: what numbers should I be looking for in a driver to run a single Rebel between 100ma-700ma.
Assumptions (prob wrong):
output Voltage 12v (constant)
output Current: .1a-1a
output power: ???W
Input voltage: 120VAC
(specific driver suggestions always welcome)
________________________________________
Assuming some form of the above driver, If I wanted to run the Rebel at 350ma for example. would I simply hook up the driver, Rebel, and a 27 ohm resistor in series? ( http://led.linear1.org/1led.wiz?VS=12;VF=3.2;ID=350 ). I apologize for my simplistic questions, but I really hit a brick wall when it comes to the technical stuff.
Thanks
output power: ???W
Thanks
