I'm wondering if 3-cell resistor-limited unregulated LED lights (e.g. Lightwave 2100, Trek 4) get as much energy from their batteries as 4-cell lights do. The idea is the Vf of white led's is 3.5 volts or so, right? So if that Vf is constant, once the batteries are down to 1.2 volts or so, there's almost no voltage across the resistor and the light would get very dim. If you use rechargeables, it would start out dim and stay that way. With 4 cells (Streamlight 4AA) you'd use more resistance and have more voltage drop to work with--you're still getting reasonable current even at 1 volt per cell.
What happens in reality? 3-cell lights sell pretty well and get decent reviews, so they must at least work ok. Is the effect I'm describing real at all?
