3 Osram 64275 bulbs. I bought these and tried the first one and broke one of the pins off when I tightened the bezel down. I thought it was because I hit the bulb with the glass (which I did) so I removed the glass and tried the second bulb. I got the reflector tightened down almost the whole way and realized the reflector hole was just slightly too small and I broke one pin off that one also. I decided to just stick with my ROP bulb and sell these rather than get a deeper reflector with a bigger hole (let's say I got a little frustrated). So, I have 3 new Osram bulbs but 2 have one pin broken off. I tested each bulb before I tried to put the bezel on and they both worked. Obviously, they don't work now and you are taking your chances with them. If you think you can solder the pin back on you can get 3 64275s for $free IN THE US. Please note I can't promise anything with those 2 broken ones. The other one is still new and sealed.
FIRST I'LL TAKE IT POST GETS THEM.
