Same old, same old: IT HAPPEND AGAIN :shakehead
http://img29.imageshack.us/gal.php?g=p1000519n.jpg
Exactly the same symptoms this time with a Solarforce R2 single mode dropin which I got as a replacement from a different seller. (Turned out the seller of the wasted Q5 dropin was willing to replace but requested me to send the broken dropin to him which was no more cost effective to me)
This one had even less total burn time (under 10 hours total) and was used for 2-3
one hour runs (constant on) for searching buildings. Then all of a sudden within one battery run (intermitted usage) the beam turns yellow/greenish and gets very dim fast (brown burn mark can be seen agin on the emitter).
The funny thing is I even wrapped the dropin thightly with aluminum foil and even used artic alumina thermal compound for an absolutely snug fit within the Surefire 6P I was using it in to achive maximum heat transfer to the 6Ps body!
Is this just bad luck, are the Solarforce dropins just no good after all (as long as it worked both of them were great)?
At the moment I'm wondering whether there might be something wrong with my 6P. Is this possible?
I mean there are no electronis in a 6P so could there even be something wrong? (I bought the 6P specifically for LED usage so I almost did'nt run it with the incan P60)
I just depend on my light and can't have any premature failures any more!
Malkoff M60 after all?
Any ideas?
