I have a 5 watt luxeon that I usually run 5AA batteries with, and using a reflector. For some reason, I can't get it to be very bright, and my 1 watt with the 30mm optic is still brighter at the spot. The side spill of the 5 watt is better, but the hot spot is not as bright, even when I took the AA dummy out and placed a sixth AA battery in the battery holder. The reflector is one that looks like it has many small 'mirrors' rather than the typical smooth Maglite type reflector. Perhaps I need to get an actual Maglite reflector. It seems to have worked with others here. But still, I have two 5 watt stars, and neither of them seem that impressive, unless they are being used as a flood. Then, they are more impressive than the 1 watt LEDs.
Any comments or suggestions?
Thanks.
Thanks.
