There is a huge problem with fresnels for flashlight systems. Firstm off the fresnel stage light is hugely inefficient. Look at the picture you submitted. The spherical reflector only reflects light out of the back of the lamp, all light out the sides is lost into the black paint void. That is why the brightness is even from spot to flood. As the lampo gets closer to the lens, more of the side emmitted light gets out of the lens. The lamp and reflector move as one. Also a lot of light is reflected back through the lamp, heating it up and is lost to refraction. This is why many people are replacing thier stocks of fresnels with par cans(round head lights in a can) and the source four par(dissassebleable head light). These lights are great, but a 575 watt 120volt four fillament lamp or the older 1000W single fillaments get outrageously hot. The ERS or leko lights get a really tight beam not only by having good lenses but wasting a lot of light in the lens train so that only the good colminated light gets out.
Now a fresnel lens that did not have the dimpleing a theatre light has, and that was backed by a lamp in a parabolic reflector, where the lamp moved in and out would give the desired effect you are looking for in a flashlight.
For a flashlight you would really need a lens setup that colminates the beam. That requires two plano convex( one to capture light from source and reflector in a general direction and another to tighten it up) A step lens, or high curviture glass lens like the ball will give the tightest beam, with the only spill coming from very off axis light.
