PCC
I'm currently considering mounting a light to my home defense shotgun and wanted opinions on what I should get.
My current weapon consists of a Remington 870 Express with the 18.5" barrel, Choate pistol grip buttstock, and a 6-shot extender that I cannot recall the manufacturer of (probably Choate). I plan on replacing the fore-end with a black synthetic one and adding a Sidesaddle. The only thing left is a light of some sort. What I'm left to do currently, if I have an intruder, is to hold my 2D Mag in my left hand between my thumb and forefinger and the remaining three fingers of my left hand to hold the slide to rack it and to support it. I'm not sure I can do this correctly at 3AM and half asleep with a ton of adrenaline flowing through my veins.
What I'm looking for:
* Flood beam so that I can see the intruder and to be able to identify if they have a weapon or not.
* Inexpensive! For a light that I never ever want to use I don't want to spend more than $100 for it and even that is a stretch. Of course, if the money needs to be spent it will happen.
* Must run on lithium primaries. I want the 10 year shelf life and don't want to pull this light after a year to find that the batteries leaked all over the inside of it. I would prefer 2XAA or 1XCR123A. I do plan on swapping batteries every 5 years or so to ensure that they are fresh. Should I do this on an annual basis?
* Must have the ability to take a remote pressure switch. Custom made is an option but not preferred.
I would prefer LED but, since this will be used rarely and only for short periods of time, an incandescent bulb would work, too. I think that the LED would be more shock resistant for the times when I take the 870 to the range to practice using it. I can always remove the light before heading to the range if the recoil may cause damage to it since it will only be used for a very specific purpose.
For mounting the light I'm either going to go with using barrel clamps to clamp the light to the magazine extension or mounting it directly to the fore-end using a short Picatinny rail. I have the ability to make my own mounts if I have to but will probably look to the aftermarket for mounting rings and such. I already have some 1" scope mounts around here somewhere, too.
Lights that I have considered:
* Solarforce L2 with Solarforce remote pressure switch, a Malkoff P30 flood LA and a dummy cell.
* Mini-MagLED with P4 retrofit and custom made mount and custom tailcap remote switch. This may be the most cost effective solution.
* Build a SureFire Lego 3P with the aforementioned Malkoff P30 module.
* Figure out a way to mount my SureFire 9N to my shotgun, make an adapter to mount one CR123A to it, and modify it with a remote switch but this will be big and bulky.
Other than the 9N, I don't own any of the above so I will essentially be starting from a clean slate.
TIA for any and all suggestions.
