jzmtl
I bought a small solar panel intend to maintain my car's battery in winter since I don't drive it often, it's only 1W (80mA) max. I hooked it directly up to the battery with wire running across firewall so panel is placed inside cab, and a 1 amp fuse inline. When I measured everything with multimeter I noticed even thou the panel is only generating about 7 or 8 mA in cloudy days, the voltage is about 22 volts. Does this sounds right? Seems really high given car battery is 12 volts, and the panel voltage will be even higher on sunny days.
