MrGman
- Joined
- Feb 6, 2007
- Messages
- 1,777
Comment__A10 R2___A10 R2__ DBS R2 SMO__Raidfire Spear Hi__Raidfire Spear Hi__DBS R2 OP__DBS MCE__Lumens FACT. EO9,
Lux @ 5m: 2021___1962____920.4________836.5___________578.2_________556.4_____395.8_________389.8,
Lux 1m:__50525__49050___23010________20912.5_________14455________13910_____9895__________9745,
(calculated) best____fully_____not___________best______________fully___________not________not_____________not ,
___________focus__tightened__adjustable_____focus_____________tightened______adjustable__adjustable______adjustable,
MrGman (me) and WBP just finished taking readings in a collaborative effort to determine which of the hot thrower flashlights had the best lux readings at 5 meters, 16 feet and 5 inches from torch front glass to Orb Optronics SP100 ($8,500.00 Spectral Radiometer) meter. In a darkened room with this calibrated meter, the following lights were tested multiple times each. Those that had adjustable focusing were adjusted for best possible readings and set to fully tightened down position. The best reading of each is shown.
The RaidFire Spear, using a very good brand 18650 battery, The Dereelight DBS 3SD V2 R2 (think I got that full title right, thrower model with R2 pill), also with a very good brand 18650 battery. Then the new Tiablo A10 R2, with 2 mostly fresh Surefire CR123 batteries. That is what it can take for best performance and since we are looking for best possible performance, that is what is used The Dereelight DBS with the MCE pill and orange peel reflector, was then tested also.
For grins I threw in the Lumens Factory incandescent Extreme Output 9V (EO-9) lamp inside a Solarforce host with 2 new AW 18650 batteries and the custom modified A/R coated glass in the bezel. This is supposed to be a 380 bulb lumen lamp. I am guestimating its 260 or less lumens out the front, have not yet measured this one.
Those readings were then compared and calculated back to 1 meter by multiplying by the square of the change in distance from 5 meter back to 1, which is 5 squared or 25, so each reading at 5 meter was multiplied by 25 to give the "calculated" 1 meter reading. We believe based on other testing that these powerful lights with big reflectors and tight spot beams are measured far more accurately at 5 meters than at 1. These units were all done tonight at the same distance and with the same meter so there is no way to say that the technique favored one over the other. Being thrower type flashlights no one is going to really use them at 1 meter anyway so we believe these results are far more realistic.
Don't ask for measurements at 1 meter, we aren't going to bother.
In case the table above gets messed up when I post this, the Tiablo A10 was far and away the brightest light with up to 2K lux at 5 meters, the Dereelight DBS with R2 pill was only 920 lux, the Spear was 836 lux, Dereelight MCE only 395, and the Lumens Factory module only 390 lux. We also threw in the Dereelight DBS R2 with the Orange peel reflector.
There is no question that the Tiablo A10 was much brighter in the hot spot than the other lights period!.
We took the 3 contenders outside and looked at some trees about 80 yards away back and forth and there was no question, the Tiablo A10 was the clear winner. Smaller but much brighter hot spot. Didn't have time for beamshots, don't want to bother with more pics of green trees in the dark, seen enough of that. At another time if necessary I shall pull out my color targets and post them about 100 yards out.
WBP simply said, "I am buying the A10 tomorrow!".
Truth is Truth.
Thanks to WBP for his time and use of his excellent equipment.
This glorious work does not include or pertain to lights with specialized optics that are so finely focused that they act like a projector. :nana:
Truth is Truth.
