Guys,
6 Volts to the BadBoy will pretty much pass through with some voltage drop to the LED! The circuit was design as a boost circuit only where the Vin should be at or below the Vf of the LED. 2 cells on a McLux is a BOZO NO No! Regulation is being bypassed! I believe all of the McLux TK's have Q3L Luxeons in them so you can probably safely use a Li-Ion cell (3.7 V) but that is the limit as far as I know!
- Don
