I've modified three Brinkmann 2AA "Rebels", two with white
Luxeon Star and micropuck, one with red star direct drive.
This is detailed elsewhere, it basically consists of removing original LED and optics (mounted in a plastic "cup". Mount Luxeon Star LED on the outside end of a 3/4" copper pipe cap. Prepr the cap before arctic silver epoxying the LED, by trimming 1/4 inch off the open end, and drill two small holes to pass the wires to the LED. For white LED: solder orange and green wires to LED, red and black to the + and - terminals in teh bottom of the plastic cup, for red, just wire LED directly to the + and - terminals. The copper pipe cap will press in neatly, do not press it in all the way to the bottom, yet..
Carefully, run a thin bead of "krazy glue" cyanoacrylate adhesive around the inside edge of the Brinkmann plastic bezel. then carefully place NX01 or NX05 optics, centered in the hole - this is almost a perfect fit. Take caution to avoid getting glue on the optics.
After the glue dries, carefully screw the bezel back on, if it hits the LED, reove it and gently press the LED/Pipe Cap in a little bit and try again. Don't use the optics to force the LED down.
This is a nice and easy mod, it will probably take less time to complete it than to read this rambling post. Makes that whimpy little Brinkmann into a mini-blaster.
The original LED circuit and optics can always be worked into some other project, too nice to just toss it...
the same mod can be done with the Brinkmann "Long Life" 2AA light, but it is a bit more mechanically complex.
/ed B in NH
