LD10 and 14500 battery
UlrikJ
Denmark
Hi
I know that when using a 3.6V 14500 battery with a LD10 all the modes does not work because of the driver. But under which voltage does a LD10 work again (all modes) when using a 14500 battery ?
Cheers
UlrikJ
Denmark
From the post of rockz4532, it sounds like I should use rechargeable AA batteries. Thanks for the help.
1996alnl
A eneloop AA battery will give me 1 hour of runtime on turbo.
Nice little light. You can screw this head onto a L2D body and cap with 2xAA's,the output is MUCH brighter with the same runtime.
