For sale is a Five Mega 2 1/4 Mag Lite, fitted with a FM bi-pin holder, a WA 1185 bulb, the 2 1/2 inch FM head, and a 3 x 17670 battery holder. The light can be operated either with the stock Mag head and bezel (included) or by removing the stock bezel and screwing the FM 2 1/4 inch head onto the threaded part of the stock head. The larger head sits on top of the stock head. The larger head improves the throw dramatically.
This is an inexpensive way to get a really bright light. According to LLuther's Destructive bulb testing chart, the 1185 operated at 12v produces about 1560 lumens. When you combine the high output with a with a well-made large reflector, you have a very successful build. I have timed runtime at 30 minutes.
$230.00 shipped and paypaled. If you want 3 x 17670 lightly used batteries, $250.00. PAYPAL IS wmlafferty (AT) comcast. (DOT) net.
Note: Included are body, stock head, bezel, reflector, bi-pin holder, 1185 bulb, 2 1/2 inch head and reflector, 3 x 17670 battery holder. Not included is a high temp reflector for the stock head. If you want to use the high temp bulb with the stock head, you will need a high temp reflector for the stock head. The larger head is already fitted with a hi temp reflector.
