nwbrewer
So right now I'm powering my P7 D---I bin with a setup like this -
Using AMC drivers in parallel to give me 2.8 amps when I close both switch 1 and 2, or 1.4 amps when I close either switch separately. My battery pack consists of 2 packs of 4 AA's (these -http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=2552)
When not hooked up, fresh off the charger, I'm looking at 5.2-5.4volts off the pack. Hit switch 1, it drops to right around 4.6, and I'm getting 1.4amps almost exactly to the LED. Hit switch #2, and I'm down to 3.5-3.4 volts, and looking at maybe 2.3-2.4amps at the LED.
So would switching to 4c's fix this? (This is in a SCUBA canlight, so the batteries go in a PVC canister, form factor is not super important) I'm also only getting maybe 45 minutes of burn time out of the light before I'm only able to pull 1.4amps. I'd really like to just switch to 4D's, but that won't quite fit in my canister. Would I be able to do it with 3D's? I'm worried that the voltage sag would happen with the D's and I wouldn't even be able to get 1.4amps.
Anybody with any good suggestions I'm willing to listen. Maybe to go Li-ion? Can you wire Li-ions in parallel? If I'm going to the trouble of purchasing a new battery pack I'd like to try and get my run time up to 3 hours or so.
Any particular brands of batteries to go for/stay away from?
Thanks!
Thanks!
