After reading a few posts about Cree domes coming off, I managed to dig up 2 patents from Cree about the their Xlamp series LEDs:
7,279,346
7,326,583
Use http://patft.uspto.gov/ to search the above 2 patents.
Here's a picture from 1 of them:
Indeed, the only thing holding the dome in place is the encapsulating gel (18), so it's not difficult to knock it off if you're not careful . Another interesting observation (from the picture and my own inspection of an XR-E), is that the diameter of the dome is smaller than the internal diameter of the metal ring. This means that there is some play involved when positioning the dome during assembly. What will happen is that you may occasionally get a Cree that has the dome off-centered in relation to the LED die (the die itself is centered within the metal ring though). I've confirmed this visually with one of my Cree Q5, the dome was slightly off to one side.
I'm not sure how much this will affect the beam when used in a flashlight but I think it does play a role, especially when there is an off centered cree-ring/corona yet the LED appears perfectly centered within the reflector. What do you think?
7,279,346
7,326,583
