GreyShark
- Joined
- Dec 21, 2008
- Messages
- 359
I live in a rural area subject to a variety of severe weather phenomena that can disrupt the grid for extended periods depending on how the dice roll. As such I have an interest in off grid systems for these eventualities. Recently I've come up with a lighting solution I find intriguing so I thought I'd share. It consists of the following,
Any P60 compatible 3x CR123 host
1 drop in rated for ~9 volts
1 drop in rated for ~3 volts
2 50mm rechargeable cells
6 primaries
1 SC1 spares carrier
The ~9v drop in and 2 50mm cells, be they 17500's or 18500's, are the primary light configuration. The SC1 holds the primaries and ~3v drop in.
Ideally you would have a backup electricity system of some sort and a charger capable of recharging the 50mm cells. A car adapter for the charger and a full tank of gas could be enough. If this fails you can run the ~9v drop in on the primaries. The ~3v drop in and 3 cell body allows you to fall back on 2 ubiquitous AA's if you have to start scavenging for batteries. This would also be useful for adventuring as AA's seem to be just about the most common batteries in the world. I would prefer a CR123/17500 body because it would hold the AA's better than the wider 18mm cell body.
You can play with the concept, adding or changing things. Some ideas would be a 2x CR123 host with optional 1 cell extender so you could run the ~3v drop in on 1 50mm battery + spacer, 1x 17670/18650, or a customized carrier layout in a small Pelican case, etc. I prefer the setup I outlined because of its relative simplicity and the fact that it consists of two basic modules, the light itself and the SC1. Both of these are durable, weather tight, pocketable and easy to keep track of. I feel LED drop ins are especially suited to this setup because of their overall efficiency, durability and longevity.
6 primaries
