AlexGT
Hi all!
I am going to recieve one diamond dragon led in a few days (Thanks Shutter :wave and want to make a Mag mod with it.
Here is what I have in mind.
Option 1
RCatR aspheric mod, using a Brightlumens P7 heatsink on a 50 x 38 mm SS aspheric, I want to have multiple brightness settings with a high of 1.8 - 2.0 amps to the led. driven by one Li-ion "C" battery from AW.
Option 2
FM 2.25 "C" with throwmaster reflector using P7 heatsink using 2 AW "C" in paralell for 3.7V 6,600 mah capacity, I might try a 70 x 65 mm SS aspheric for throw, also with multiple brightness settings with a high of 1.8 - 2.0 amps.
Now the driver,
I want to figure out a good driver that has modes and can drive the led at up to 2 amps on high.
Several options here
I dont know if DX 7882 driver can handle the constant 2 amps on high or only for a small period of time
http://www.dealextreme.com/details.dx/sku.7882
Another one would be a 1.2 amp 7135 driver with modes
http://www.kaidomain.com/ProductDetails.aspx?ProductId=1696
And add 2 or 3 7135 350ma circuits to get 1.9 amps, I have a spare 7135 driver where I could salvage the drivers from.
Option 3
Combination of 7135 and another slave driver to get me around 2 amps like StefanFS did.
Option 4
Bi flupic for 2.4 amps on burst or maybe If I can get one with a limited burst of 1 amp per channel for 2 amps burst.
Do you think the DD can throw well with an aspheric or a throwmaster reflector? I am assuming that the DD can be heatsinked well on a Brightlumens P7 heatsink and that it could handle the heat of a 2 amp led.
What do you think about the driver combinations? Am I missing another good driver with modes that can give me 2 amps on high?
Thanks in advance for your toughts and suggestions.
Sincerely
AlexGT
Option 1
Option 2
Now the driver,
Option 3
Option 4
Sincerely
AlexGT
