Help with DBS user interface.
TAIGERSX
Virginia
I just got my DBS V3-3SD. However, it seems like I can't switch to the higher level. The instruction says " press and hold the switch slightly within 1 second for mode change".Does it mean press the button half way just like we do with the Fenix P3D or PD30 ? am I doing anything wrong ? :thinking::thinking: Or I need to charge my newly-bought-18650 battery ?
Thanks a lot
HKJ
Copenhagen, Denmark
Press the button down until the light turns on, but not so far down it locks.
When the light turns on, release and press again, this will step to next level.
jblackwood
Miramar, FL
Yep, just like signalling with a forward clicky. The order of the modes is Low, Medium, High. When in doubt, I usually cycle through until I hit low then two more quick clicks and :hitit:
The "it" in this case being the High mode.
