etc
Here we go, once again displaying my great photography skills (if the pics come out too big, I can resize them)
Left to right:
Malkoff M30 with 3xAA FiveMega body
Malkoff M60 with Leef body designed to run on 5V-12V (2x18650 or 4x123)
Malkoff M60 on 2x18500 Leef body or 3x123
Notes:
The best tint is on the "original" M60 (it won't accomodate 12V BTW). It's the most practical size for EDC, just a hair longer than Mini-M*g.
The 2x18650 should offer the best runtime of at least 3 hours and even more on 4x123 primaries. It's most comfortable to hold, the grip is excellent. I kind of like the even number of cells, a box of 12 cells should offer 3 spare sets. Plus I like 18650s more than other sizes, I think they are most common and most likely to get developed. I am looking forward to 2800 mAh protected cells. These are "only" 2200 mAh AW cells.
M30 is a hair brighter than both on Lithium primaries and noticeably dimmer than both on NiMH cells. (maybe 200 lumens vs. 235) One huge advantage of the AA lite is that it dims gradually. The AW cells cut out instantly. Unless of course you use 123 primaries.
I have come to realize I like Li-Ion better than NiMH but its flexibility is neat. M30 will run literally on any AA cells, including Alks, NiMH, even the dreaded "heavy duty" junk cells. The quality of the 3xAA FM body is excellent, although I wish it had a separate tailcap.
Still trying to decide if I should get a custom made M30 to work on up to 6V so I can get a 1x18650 body and run either Li-Ion in it or 2x123 primaries. The original M30 runs up to 5.5V.
The important thing to realize is that if Li-Ions are not available, you can always run primaries, and if these become unavailable, you can always run some kind of AA cell. I ran M30 on 3xAA "heavy duty" carbon-zinc cells and got 3 hours out of them, although it was less bright as an old 1W from circa 2003.
In sum, in that configuration above, I don't really need any other "AA" lite, although multi-mode would be nice.
In final note, you notice that the 3xAA and the 2x18650 are in mint condition, the lite that actually does get used on a daily basis is the Surefire 9P clone (2x18500 Leef), partially due to its compact size or maybe due to its superior tint. It's not a "W" version but halfway there.
Left to right:
Notes:
