Well, it arrived. I was surprised how underpowered it was compared to my D10 R2, EX10 R2, and even the new Q5 Eagletac P100's.
I was freshly charged running NiMH eneloops.
My D20 is the first NiteCore R2 sample was the first to not be suprisingly bright. Instead, a disappointment. I think much of it has to do with an emitter that sits low, below the back of the reflector. Perhaps it needs a thinner insulating washer?
Anyway, I upgraded it to Q3 5A emitter, and it seems just as bright as before changing the emitter. I even gave the emitter board a copper boost. Maybe that helped make the hot spot better.
As usual, it continues to unintentionally turn on if you bump the tail of the light. This is the biggest disappointment, they've had plenty of time to fix this problem.
The color is not burgandy, thank goodness.
The quality is superb, just not bright or focused as the rest of the family.
In the picture below, the light on the left is (was) Q5. The 3 on the right are brand new R2 versions.
