[ QUOTE ]
e=mc² said:
If you have any leftover Everleds, they use the same technology as the MicroPuck, so you can see first hand.
Ed
[/ QUOTE ]
This is true only in the most general sense, that is they'll both drive a Luxeon on with two cells. While the micropuck is an 'open loop' boost thingie (the output goes up as the input voltage goes up), the Everled has a 'proper regulator'. That is once you get 'on the curve', current drawn goes *down* with voltage rises, output stays constant:
1 Volt, .01 Amps, 9 Fc (Foot Candles)
2 V, .46 A, 450 Fc
3 V, .42 A, 570 Fc
4 V. .35 A, 630 Fc
5 V, .29 A, 650 Fc
6 V, .24 A, 650 Fc
7 V, .20 A, 650 Fc
8 V, .16 A, 650 Fc
9 V, .13 A, 650 Fc
The micorpuck, of course just gets brighter and brighter and brighter.... Kind of a 'chicken race' between the micorpuck and the Luxeon to see who's first to the promised land.
This gives you a whole different sort of output profile over battery life. For instance a 6 Volt flashlight on alkalines is still at very near full brightness when the cells hit the very end of their life at .8 Volts each (3.2 total).
OTOH, the micrpuck (on two cells) has a 'useful battery runtime' (to half initial output) at a bit over two Volts, where we still have 15 or 20% of the total capacity of the battery left. That is when the micropuck has 'wimped out' and gradually dimmed to half brightness, the everled is still clicking along full tilt.
A entirely different technology really. Depends on what you want. Each has it's advanteages, of course.
Doug Owen
