hello i am looking for test or a review for the solarforce L 950 2 x 18650 powered version . I have done a search for a review on the forum but have not found anything relevant maybe someone knows where to look for it . Somebody please point me in the right direction.cliff
This is a current thread that will help get you started:
https://www.candlepowerforums.com/threads/226100
If you do a google search on L900 reviews, that will also be applicable.
The reflectors are identical, the output is so similar that you will need instruments to tell the difference, the slight color tint difference is not a big concern. The main difference is that the three cell versions are only single mode, always on high (which I prefer for security work). The two cell version has the same output, but less run time on high and a 50% output level that will run for about four hours if I remember correctly.
I have the L900 (3 18650 cells P7) and the T700 (3 18650 cells with 3 Q5 emitters). They are both top notch lights, highly recommended!
Best regards,
DGM
