harada77
Just got Jetbeam M1X~ :wave:
Look very Nice!!!
Right is M1X
20~30M beam shot...
So....technically, is there any difference in major performance between the L900 and the L950M? Looks like the M1-X spanks the L900 in terms of spill wideness and throw.
You are correct, I edited my response. I based the first observation off of the building shot, but I saw later that the flashlight head was blocking a full view.I don't know it there's any difference although the L950M is supposed to be a bit brighter.
However, from the beamshots, I'm reading that the L900 has a wider spill than the M1X although the spill is less intense.
Sometimes, its quite hard to see the spill properly in these beamshots, if the spill from the overlapping light is brighter.
In the top beamshots, imagine drawing a circle around the circumference of the outer edge of the beamshot for the light on the left (the L900).
This will make a bigger circle than for the M1X.
M1-X has brighter hotspot though....which = more throw.
The MC-E is the smaller package compared to the SSC-P7 though, so presumably the light intensity emitted by the MC-E is greater, meaning that for the same size reflector, the MC-E will throw quite a bit further.
No because smaller lens work as a magnigier. Magnifies dies (look at them side by side - P7 dies look much smaller) and also 'light emitting surface' (whatever it's called).
Reflector design might also play an important role. Deeper vs shallower....
Perhaps the OP can show us reflectors side by side of the L900 and M1-X?
Yes this might be true. On the other hand I always thought that the diameter was more significant
than the depth of the reflector as far as throw was concerned. :shrug:
Maybe a course in optical physics would help me.
LOL, it would help me too!!
I think the depth to diameter ratio plays a large part....as well as the size of the light source. Take the Sunlite 16w for example...which I have done a lot of beamshots with already.... It currently, to the best of my knowledge, has the farthest throw of any quad emitter out there right now. According to Glenn7, it beats the M1-X....according to these beamshots in these photos, it beats the L900 because the M1-X beats the L900, in other threads that compare the 16w to the Wiseled tactical P7 and the Wiseled tactical P7 to the TK40, it looks to have more throw than the TK40.
It has not been tested against the M2 or M2X yet, nor the M30 Triton....but time will tell there.
My point is that the 16w quad emitter is not packed in a dome, so the light source is 3mmx3mm and the reflector dimensions are 44mm diameter x 45mm depth.
If reflector diameter alone determined throw, then all of those mentioned above 'should' throw further.
I appologize of my conversation above if off-topic a bit....just trying to rationalize the part a reflector plays in all of this discusion of quad emitters in the high output lights....
I was heavily contemplating getting the new L950M to see how well it compared to the 16w, but I might forego that now that this thread has popped up. Hmmm:shrug:
It certainly beats the MG-RX1 for throw (just tried them out in the garden) and the MG-RX1 is no slouch, since it beats the Tiablo ACE-G.
But I don't think it can beat ACE because it has much deeper reflector than ACE-G. Throw is similar or even better tahn M1X.
