nailbender
Hi All well this started out as a good idea and went down hill fast. KD is not able to furnish these lights and have dropped TAC and the TLS light from their website. They are not going to deal with this manufacturer anymore. When we switched from the head only to a very well priced flashlight things went down hill as the various items we wanted were not available on the light that KD offered.
I actually received the lights but they were of multiple configurations. When the wrong heads came in the company would not guarantee a time when the proper heads would be delivered. The first and actual TX3 head is now available only through one distributor and not available through KD. 1/2 the lights delivered to me would not fit any Surefire products because of a changed drop in design and no one wanted to replace it. It was an easy fix but between the factory and KD it became a problem. The factory could then not even deliver the head that was on their website.
In their defense I do believe that KD tried to make this happen and that TAC was the eventual down fall but who knows.
I am sorry for any inconvenience and I am glad I did not make this a prepay so at least I am the only one that has to be repaid and I will be taken care of.
Please PM with any questions.
Dave
PLEASE READ REPLY #16
This is an interest thread for modifying a batch of TLS M heads from Taclight with Cree MC-E in cool or warm whites.
These are well built after market M sized heads to fit Surefire Special Ops Lights and Millennium Weapon Lights.
These come with a Q5 and a 2 level driver. I did not get near enough current to be able to use the drivers with a MC-E.
I am replacing the drivers with a 1.4 amp driver and wiring the MC-E 2S2P. These will unless I find a different solution will be a one level light.
They would be available in Warm and Cool Whites but the upper end of the cool whites.
Here are the Picts.
The HAIII matches very well with both of the above
Shot from the top
About the brightest and tightest spot on an MC-E that I have had
Without any focusing the beam was almost perfect, This was an M bin MC-E that is about 7500 K. The beam had the smallest of holes in the center which took less than a 1/2 turn to smooth to about the smoothest MC-E beam around.
The throw was literally almost as good as an R2 but more spill.
The operating voltage will be 6 to 14 volts
These TLS heads come in smooth or OP in reflectors
They come in Black or Natural
There are also M2E adapters & M2C adapters making these a very configurable product.
The price will depend on the number of these bought but they are a quality Turbo head and will end up in the $200 range.
So lets say until we see where this will go they should be $200 shipped CONUS and again will depend on the number there ends up being.
Thanks
Dave
Well here is the list Red is confirmed
Dave
- These are Aluminum bodies, Mil-Spec Type III hard anodized with O-ring sealed
- Available in Black or Natural
- Reflector is 2.4 inch TurboHead reflector, it is designed to produce a tight beam for long-range illumination
- Available in smooth with little spill and OP for more spill and a super smooth beam
- This is a quality built head with a nice heavy duty reflector.
Here are the Picts.
Shot from the top
Thanks
Dave
- Name Finish Reflector Bezel LED tint
- Led Zeppelin Natural - OP - SB
- Qtrhorse Natural - ? - ?
- Justin Case Black- SM - SM - WM with questions
- BSBG Natural - MOP - SB- neutral white
- DStutts- Natural - SM - SB - Cool
- OpenBolt1 Natural -MOP - Strike - Cool white
- Mudman CJ Natural - smooth -Strike - K bin
- JDriller Natural - MOP - SB - Neutral/Cool
