GreyShark
- Joined
- Dec 21, 2008
- Messages
- 359
This is my daily carry but I've never performed a runtime test. I've heard it suggested that the M60 will get 45 minutes of runtime on two 17500's but that didn't seem to be consistent with my experience. I don't know how many amps the M60W is drawing at 8.4v and I don't know if it draws a little less than the M60 does. I do know the M60W is rated at 170 lumens whereas the M60 is rated at 235, though the practical differences in throw seem to be more or less negligible to me.
So... the M60W ran for 2 hours 4 minutes continuously on 2x 17500 experiencing only a slight reduction in brightness after 1 hour. It was at all times more powerful than the M60LL or P60L running on the same batteries. As expected it also gets quite a bit warmer when sitting on the table than it does when held in the hand.
The interesting thing to me is that the AW protected 17500's are rated at 1100mah each for a total of 2.2 theoretical amp hours. While I can't say how efficient this stacking is because I don't know the M60W's draw at the concerned voltages the max potential runtime based on a 750mah draw and the 2200mah capacity would be 2.9 hours. Since there are more variables to consider than just those and I'm getting closer to 2.1 hours it's plain to see that the M60W's driver is good at getting the most out of the available cells. Off the cuff I'd guess that the M60W would get around 3.5 to 4 hours off 3x CR123 and that may go higher if the drop in voltage corresponds to a significant drop in draw.
