makesomenoise
- Joined
- Nov 30, 2005
- Messages
- 7
Hi all,
I have a P3D shelf queen i bought in early 2007 which i have recently started using.
After loading the batts in, it will start to drain itself dry.
For the last few set of batts I used it on, it will drain itself and low batt indicator will set in on the lowest mode in about 4 weeks.
For the sets of batteries, I have only used it 30mins max on high.
For the last 2 sets of batteries I used it on, I actually did a tail cap lockout on them. Never the less, the batts continue to drain.
I have read on other threads that it is probably because of faulty O-rings.
2 questions.
1) Will the low batt indicator go off after blinking for a while or will it continue to blink till I switches mode?
2) Will swapping the o-rings solve my problems or it there some other issue I have to aware of?
Can somebody advise me on the above?
Many thanks.
2 questions.
Many thanks.
