Wuben
Results 1 to 9 of 9
Thread: SSC P7 Lens
    Flashaholic* old4570's Avatar
    Feb 2009
    Melbourne - Australia
    Default SSC P7 Lens
    Is it possible to clean the LED lens on a SSC P7 ?
    I just got my first Spare SSC P7 and the lens on the LED is much clearer than the one in my flashlight ...
    Or is it normal for some to have a more murky lens .
    Flashaholic* nein166's Avatar
    Feb 2006
    New York
    Default Re: SSC P7 Lens
    Yes it can be cleaned, from the Seoul Semiconductor P7 PDF
    • This device should not be used in any type of fluid such as water, oil, organic solvent and etc. When washing is required, IPA(Isopropyl Alcohol) should be used.
    I have been cleaning my silicone dome LEDs from SSC with 70% or greater IPA with no ill affect. The higher the concentration the less water in the mixture.
    I just dip a qtip in IPA and swab it over the LED, let the IPA evaporate and close up the light.
    *Flashaholic* easilyled's Avatar
    Jun 2004
    Middlesex, UK
    When I went on holiday to Caribbean Grenada many moons ago, I bought a bottle of local rum from a distillery that was 70% proof.
    Apart from the tiniest drop, none of this has been imbibed. I am now using it for cleaning the gummy domes of my P4s and P7s
    by soaking an end of a q-tip in it. Then I dry it with a blast of compressed air.
    This seems to work well and I've noticed no ill-effects.
    We are all flotsam and jetsam being carried by a relentless tide towards our ultimate fate!
    Flashaholic* monkeyboy's Avatar
    Mar 2006
    UK
    70% proof is 35% by volume. I've always found that to be a little confusing.
    Retired Administrator Norm's Avatar
    Jun 2006
    Australia
    I use the same sort of swabs the doctor or nurse uses before doing a blood test or injection.
    They also work very well for cleaning any small excess of Arctic Alumina around your LED.
    Feb 2009
    Quote Originally Posted by Norm View Post
    Ooooh , nice one !
    Thanks guys , Alcohol !
    Jan 2004
    Pleasanton (Bay Area), CA, USA
    Quote Originally Posted by monkeyboy View Post
    Before or after consumption?
    Powered by LibreOffice and Linux Mint
    I would use a lintless, microfiber cloth, dipped in IPA to clean the SSC P7 dome (also fine for SSC P4 domes). These sorts of cloths are the same ones people use to clean their AR-coated, plastic lens eyeglasses. Dip a corner of the cloth in the IPA and then gently brush the wetted corner along the surface of the dome to pick up the debris. Don't use your finger to press the cloth into the dome. You risk dislodging or otherwise damaging the dome.
    Feb 2006
    New York
    Quote Originally Posted by Justin Case View Post
    Thats a great idea! No longer will I use the Qtip
