Calina
Is it possible to run the L1D on a battery other than AA Nimh or alkaline?
Thank you for the answer but maybe I should have been more specific.
I'm still puzzled! The CR123 are available in 3.0 and 3.7 volt configuration; why is not possible to get the same in a 1450 battery or other format for that matter?
There are. Li-Ion is available is most any size you can imagine. If you want a lower voltage rechargable option, LiFePO4's are also available in a variety of sizes.
Most of the 3v cells in any size other than CR123 are designed for low current draw, and are not suitable for high current applications. Cost and interoperability are two more reasons they are not common.
