Gransee
Last week I commissioned a light lab in Scottsdale to test our lights and several of our competitors. They are testing 18 lights for lumen output and color tempurature using an integrating sphere and a spectrometer.
The lights being tested are:
5 LSH-P
2 LSH-S
2 LSL-P
2 AWS
2 AWP
1 X5T
2 KL1-E1e
1 E1e
1 E2e
Multiples of some of the LED units were tested because LEDs have more variations than incandescent. The more lights we test of a particular model, the better representation we get of average output from unit to unit.
All lights were pulled from stock at random and were not pre-tested for output.
Note: Because of variations among LEDs, these tests should not be understood to be an absolute comparison between models. The purpose of these tests is to provide a "ballpark" comparison between each model.
Furthermore, although these tests are being done by an independant lab, the test units themselves are being provided by a biased party (Arc). Although we did pull them from stock at random, we also limited the size of the test to 18 units (for cost reasons) which will also affect the accuracy of the test.
Competitor lights are trademarked by their respective manufacturers.
Here's some pictures of the test equipment being used:
A large and very expensive intergrating sphere. This is used to provide a high accuracy lumen measurement. It also has a fixture for measuring spectrometry. An integrating sphere is used to measure the total output of a light source because it can capture a representation of all angles of the beam.
Inside the sphere. Note the reflective coating and the fixtures for mounting lamps, etc. This coating is a proprietary mix that evenly reflects a wide range of light wavelengths. This sphere (minus the measuring equipment) is over $10k.
The measurement equipment. This takes a sample from the sphere and calculates lumen output and color temp (among other things).
These tests will take about 1-2 weeks to complete. I will post the results here when they are ready. I imagine the results will be in lab form which I will scan into jpegs.
Peter
5 LSH-P
2 LSH-S
2 LSL-P
2 AWS
2 AWP
1 X5T
2 KL1-E1e
1 E1e
1 E2e
Peter
