Can you share any photos please?
The M95 features the LU60 Lamp Module.
The LU60 Lamp Module consists of the "M2" Shock Isolated Bezel, the P60 Lamp Assembly, and the LU60 Lamp Module Adapter Collar.
The Lamp Module Adapter Collar allows the Lamp Module to attach to the Millennium Universal Housing Body (called the MH90).
The current version of the LU60 Lamp Module Adapter Collar has notches cut into both sets of threads to enable it to be removed from the Shock Isolated Bezel, or the Millennium Universal Housing Body by means of a suitable screwdriver shaft (etc) or the back of a strong blade (etc).
Here is a photo of an early version of the adapter collar:
Here is an example of a later version of the adapter collar:
I'm not able to post photos of the current version but you can email for them if you want.
Edit:
or see it here
SureFire has never wet-sealed (glued) any of these threads as the P60 is a user-replaceable consumable. The reason why SureFire have cut notches into the Lamp Module Adapter Collar threads is because they can be a pain to unscrew from both the bezel and from the body as it's difficult to get sufficient grip (regardless of the styling SureFire use) without the appropriate (sic) wrench.
Please let us know how you get on!
Al
