If so, I would expect that they would have enforced it by legal means long before now... More than likely it's unenforceable if it exists.
Do you have a US patent number, Al? I would be curious to see the patent. Understand I'm not trying to be a wise-butt, but I've heard this argument before and the weight of evidence seems against the existence of this patent.
The closest I could find with a patent search (
http://patft.uspto.gov/netahtml/search-bool.html) under "Matthews; John Wallace" and "Kim; Paul Youngcho" were the following:
"A flashlight beam is cast with a first lamp and reflector assembly, an alternative second lamp and reflector assembly is substituted for that first lamp and reflector assembly and a second light beam of a different configuration is cast with that alternative second lamp and reflector assembly."
Which describes 2 separate lamp assemblies, not 2 sources in one reflector.
And this one:
"A flashlight having a flashlight head with two merged yet independent lamp/reflector systems, the head including a common reflector structure having two reflectors of differing light projecting characteristics, the two reflectors arranged side by side with a common boundary across part of the common reflector structure."
Which describes 2 lamps in 2 merged reflectors.
Besides, the 9N uses 2 incandescent bulbs (correct?), not an incandescent and LED.
My primary point was that it's hard to call the TT a knockoff of the A2 when:
1) other incandescent/LED lighting solutions were already on the market
2) The A2 has very significant additional features not found in the TT lights
3) A "knockoff" implies generally identical in form and function, which is not the case here.
For that matter, if the criteria used to consider the TT a knockoff of the A2 are applied evenly across the board, I could call all of them knockoffs of the Streamlight Trident, which also has 3 LEDs and an incandescent bulb in one reflector... So what if they have completely different features. /ubbthreads/images/graemlins/rolleyes.gif
