MrNaz
I've been told that the XP-E LEDs can only take up to 700mA of current? Assuming I have very good heat sinking, is it really true that an R2 binned XP-E LED can not be driven up to 1A?
So yeah an XP-E will survive 1A if you do a good heatsinking job.
Oh sure it won't live the full 50,000 hours or whatever they say it will at 700mA but the next new super LED will be out before it dies anyway.
Take the risk.
Believe you me, this is one application where heat sinking will not be an issue. The MCPCBs will be mounted directly onto a _huge_ aluminium heat sink that will be immersed in the ocean. Thermal mating will be done with Arctic Silver 5, adhesion will be achieved with Arctic Silver Epoxy.So yeah an XP-E will survive 1A if you do a good heatsinking job.
This is about as close to the ideal thermal situation as you can get. Under these conditions, what would the XP-E say about 1.4A? Is that going too high? How high can I reasonably go while retaining a reasonably long lifespan?
Cheap enough !
I have a Q5 XPE on order , and I already have a R2 ..
I have a 1A buck boost driver Im going to swap in shortly , will see how it goes .
Q5 will go into a maglite ..
at that die size you better have the heatsink on ice!
XR-E has the same sized die as the XP-E. Difference is XR-E is on a SiC Diode/substrate, enhancing its thermal properties.
