Sold/Expired SOLD: Custom Ostar Mag *Stealth* Beamshots, 175 shipped!!
spc
Troutman, NC
SOLD
I call it the Stealth because its all smooth, black and with a tailcap switch. Looks stealthy imo..
Custom QY Ostar (shaved down)
Maxflex4
Custom sink
Custom tri-bored and threaded smooth maglite
UCL lens
Custom cut aluminum MOP reflector
FM 3x17670 holder included (17670 cells not included)
Custom made tailcap clickie switch (made with serviceable mag parts)
*This is a single mode light. The maxflex is set on high and potted into the heatsink (bulletproof!) You can take the light apart and change modes because I left the sw wires out (see pic). I shaved the ostar down so the reflector wouldnt have to be reamed so much. It helps in making the beam tighter. The beam is very nice/ smooth. I enjoyed making this light, but now I want to make another but brighter!
I would like $200 shipped and insured (conus) will ship internationally, PM me for details
Now 175 Shipped! I need the $ more than I need to hang on to this light!
First written "ill take it" gets it!
bigchelis
Prunedale, CA
Re: FS: Custom Ostar Mag *Stealth
These LED builds are great, here are the numbers on some that were tested by MrGman. These are peak turn-on readings. There was another one tested that did 680ish out the front it was Alan B's Mac Custom Osram build running 3 AW C li-on cells. Surprisingly these 6 die emitters thus far (only the ones tested) are making less out the front than P7 Mag's.
Have you tried NiMH cells? in Mag P7 builds they net about 100 more out the front lumens then the Li-on counterparts.
Osram O-Star_______Arcmania Super_F-V,___4 AW RCR123,___639.1__1 sec
spc
Troutman, NC
Thanks bigchelis!
Sounds about right, not the brightest emitter- though the ostar is more exotic IMO :cool:
Haven't tried it with nimh cells, you would need a bunch (you couldnt fit enough in this light anyway)
I'll get some beamshots tonight
spc
Troutman, NC
heres from about 35' away on brown/yellow
these are about 20' away on green walls
heres a shot from 5 or 6' away to show the smooth beam
spc
Troutman, NC
Re: FS: Custom Ostar Mag *Stealth* Beamshots, (Price Drop)
Price drop :twothumbs
spc
Troutman, NC
Bump with price drop 210 shipped
OceanView
spc, very nice looking build. I like that smooth look, and you're right, very stealthy.
Could you clear up something that I've been wondering about. Two things, actually. First, so with the tail switch, it is not possible to change any settings on-the-fly, correct? Like ramping up and down in brightness with quick presses?
The other question is--you mentioned that you left those wires to the Maxflex exposed, but I have no idea what it would take for the user to actually make any changes. Could you explain that? What needs to be done to make a change to any of the Maxflex settings? I'm just a user, not a modder, so to me "Take the light apart" could be anything from simple, to a messy kind of procedure that requires a soldering iron and more thermal paste.
Sorry for all the questions, but I don't recall ever seeing a set up quite like this for sale before. Thanks. Good luck with the sale.
spc
Troutman, NC
Thanks!
You are right on the tail switch. Its just a basic clickie- power on, power off. The maxflex remembers the settings I have it at and acts like a single mode driver.
About the switch wires= They are not just flappin around inside, I trimmed them and tucked them nicely and added a spacer that connects power to the pos of the battery in case your wondering. In order to change the settings on the maxflex you would have to tare down the light, give the engine power and touch the two wires together like a switch to change modes. I would recomend just keep it at the highest setting (what I have it at).
To take the light apart you would pop the snap ring out of the top and everything will slide out.
OceanView
Thanks for the explanation, spc. Good luck with your sale.
spc
Troutman, NC
Heres a pic of the snap-ring holding it together
spc
Troutman, NC
Re: FS: Custom Ostar Mag *Stealth* Beamshots, 210 shipped
200 shipped!
spc
Troutman, NC
Re: FS: Custom Ostar Mag *Stealth* Beamshots, 200 shipped
bump for price drop!
200 shipped
Hammer Train
Banned
Is this compatible with a KD aspheric lens?
spc
Troutman, NC
I don't see why it wouldn't, I had the tube threaded to exact oem maglite specs and the only mods to head are a UCL glass and a mop aluminum reflector. I don't have one to check so I cant be certain.
spc
Troutman, NC
Re: FS: Custom Ostar Mag *Stealth* Beamshots, 175 shipped!!
I will now let it go for 175$ shipped
