If you're referring to P60 style drop-ins, maybe this thread might help.
I have tried various drop-ins for best throw, seems the advice given in this thread has been proven right IMO. Latest Dereelight R2 with SMO, same output now for both 3SM and 1SM.
I actually got this from dereelight. will it work with rechargeables? I also got a couple of DX bulbs...will they work also?
1SM-1(1-stage multipower, constant output 3.8~8.4V) XR-E Q5 module with OP
The Solarforce pill from DX will work with the same reflector as the Dereelight. The SMO(polished) reflector will have more throw than the OP, the spill just won't be quite as bright, and there will be more pronounced rings around the hotspot. I have the SolarForce 5 mode, Dereelight 3SM 5A, and both reflectors. What I want is the single mode Q4-5B Dereelight dropin.I actually got this from dereelight. will it work with rechargeables? I also got a couple of DX bulbs...will they work also?
I have nailbender's [email protected] dropin with 36mm reflector, and it doesn't throw well at all. Very floody beam.IMHO: The dereelight smooth reflector lights will create an ugly beam. I swithed back to orange peel.
If you want more throw why not get a bigger bezel from lumensfactory.com, they will allow a 6P type hosts to accept a 36mm bezel.
Get the 36mm bezel, then have Nailbender build you a D36 drop-in with an R2 driven at 1A~1.2A. This will give you the most throw and under $75 dollars for all the parts and drop-in.
And the Malkoff MC-E is pure flood.
And the M60 is nowhere near the brightest single die P60 dropin.
I doubt what the OP is looking for here is a nonstop stream of bad information.
He uses OP D36 reflectors. Don't know if he has SMO for other emitter types, but the K2 won't focus with SMO. It doesn't throw better than the D26 OPs with Cree emitters, either. I bought that module expecting throw, myself.I wonder why there is no more added throw. I expected a larger reflector to throw more:hairpull:
I have a Dereelight MC-E pill on the way for it, since the Dereelight pill makes direct contact in my M3 with no spring needed.
If you still have the K2 drop-in, try it with the Dereelight D26 OP reflector
