Sold/Expired FS: ME II w/Luminus LED SST-50. SOLD!
ARC mania
The land of the rising sun.
I have up for sale one ME II (1 x CR123 powered) with a WJ in brightness Luminus SST-50 LED. This is mint #051 and comes with a titanium bezel as well as carrying case. Asking $450.00. Shipped anywhere in the world by express. If you are interested, send me a PM. I can also offer you a multi function version of the ME II which will be $30.00 more. It will have three levels of light and capable of running an RCR123 rated at 3.7 volts. Regardless, this thing is super bright!
MEII flashlight specs:
7075 aluminum
2mm thickness SchottB270 double AR coated glass.
Aluminum op reflector.
LED: Luminus Phlatlight LED, SST-50: WJ brightness.
Drive current to LED 1.6 amps (Multi function version is only 1.35 amps in high)
DC/DC boost converter.
Single mode.
Battery: CR123 x 1 (Multi function version accepts 3.7 volt RCR123's.)
Gold plated contact points
Gold plated positive contact
Gold plated spring
HA III olive drab
Anti-roll collar
Silicone o-rings
Serial number
Titanium scalloped bezel
Carrying case included
ARC mania
ARC mania
Re: FS: ME II w/Luminus LED SST-50.
Its roughly about 10% to 15% brighter at the same drive current. The nice thing about this LED being a single die is that it throws a perfect beam unlike an MC-E which at times has a slight X show up in the beam when a short reflector is used. I only made one of these ME II's with this LED. Its a PITA cramming things in small size.
ARC mania
donn_
Great South Bay, LINY
Mike...have you tried one of these emitters in a longer and wider reflector?
If you have extra emitters, I'd be interested in a couple or a few.
Have you tried the SST-90?
ARC mania
donn: The SST-50 will work in something like an McR27XR, kind of a long reflector. I have several of the SST-90's and they are pretty nice. The main problem with both LED's is that the need a lot of current to reach its binned brightness. Sorry, the current batch of SST-50's and 90's are all used up. I will be getting more and will put a small batch up for sale.
Getting back to the ME II with the SST-50, if you choose the multi function model and you get tired of its settings, you can send it back to have the sequence or functions changed for a small fee. This light is like a hand concealeable 10 watt HID.
ARC mania
bigchelis
Prunedale, CA
In case anyone wants to know the real out the front lumens these LED's and the SST-90 put out PM Nailbender.
He as already made some for testing and he has MrGman built and calibrated IS Sphere for real out the front numbers.
