Beretta1526
WOOF! SureFire \"G3\" 200 lumens - it works!
OK, here it is, a yellow G2 converted to a "G3" with only a couple parts and minimal work.
Originally posted here: "G3" original post
It's quite simple, a G2, P91 HOLA, an AN-14 adapter, an extra 123a, and a cut-down Z20 battery spacer (or Z29, exactly ¾" not including nub). If you want the Pyrex lens, add a G2z bezel. I don't feel the G2Z bezel is necessary unless you intend to have the light on for more than 5 or so minutes. Besides, you can always get one if you melt the lexan.
Here's a couple pics:
Total weight (with lanyard) is 6.5oz and total length is 7 1/16". If you should want it to be more water resistant, it is necessary to plug the tiny hole in the A19 adapter
