tvodrd
*Flashaholic* ,
Having turned-down a number using double-sided tape, I figured there had to be a better way. For those of you fortunate enough to have access to a lathe:
The double shielded ball bearings are 1/4ID, 1/2OD, 3/16W, McMaster cat# 57155K57. The thrust bearing is a Torrington #NTA-411, and the thrust washers are Torr. #TRA/TRB-411. The nose insert is a pressed-in Teflon piece, and I drilled it with a #4 center drill (60deg) which is close to the NX-05's 58deg. The "spud" for the lathe chuck/collet has a thin piece of silicone rubber crazy-glued to it for added "traction." I did 4 optics before I bothered to glue on the rubber, and it still worked. Reason it's so small is so I could do a couple .45" dia (N-cell /ubbthreads/images/graemlins/grin.gif)
Larry
Larry
