dubliftment
- Joined
- Jul 24, 2009
- Messages
- 126
Hi Folks,
although following the discussions around the "after" Jet-III PRO IBS models, I couldn't find anything definitive about the differences of the two available driver circuits of the Jet-III Pro ST. Right now both versions are available, but the LVC (0.7-4.2 input voltage) seems to become rare while the Broad Voltage Circiut seems to prevail.
So there are a couple of questions.
1. Are there definitely only those two circuits mentioned above? At BOG I saw a "18650 only" mode (which is no longer available now), and at http://kazwholesale.en.alibaba.com/...eam_JET_III_PRO_ST_LED_Flashlight_18650_.html they specify the input voltage between 3.6 and 4.2V. Does that mean a third version of the ST that would run neither on (adapted) AA nor on CR123A cells?
2. As to the two "low" and "broad voltage circuit": which one of these is more efficient? Which one will deliver the lowest output? Which one the longest runtime on Med/High?
3. What means "Buck and Boost Current regulated"? Are both the LVC and the BVC fully regulated, or does a 18650 run partly unregulated in either of the circuits? What does that mean for the lifespan of the rechargeables used?
4. Finally: which one of the Jet-III Pro ST is the better flashlight? Of course, if there are no runtime differences this questions reduces to the decision which battery types should be used. Including (adapted) AA cells with the LVC or including 2xCR123A/R with the BVC. But still I'm interested in your experiences.
thank you
EDIT: Is the 0.7-4.2V circuit of the ST the same used in the Jet-I Pro V3.0?
thank you
