Modern_Major_General
- Joined
- Jul 27, 2006
- Messages
- 140
First off, I want to clarify that I am a fan of Malkoff's products. I think he makes the best LED drop-ins for Maglights and Surefires, and I think his products are better than the Surefire P60L and Maglight MagLED.
I got a M60 drop in last September. I got it to replace the P60 incandescent bulb in my department issued Remington 870 shotgun that was equipped with a surefire forend. I installed the module with the copper fitting ring that is required when using a shock-absorbing head and it worked great.
My department has shotgun/handgun training about once every other month, and I also used my shotgun w/ M60 during a three day survival school. After the last training shoot a few days ago, the module stopped working. The shock from the weapon's recoil caused the optic inside the module to pop right out (It was rattling around inside the bezel behind the bezel's window). Even after snapping the optic back in, the module still doesn't work. I even tried it in other surefire lights to make sure there wasn't a problem with the forend itself. Apparently, something inside the module was damaged from the recoil as well.
Like I said, I like Malkoff's products, but I don't know if they where intended for hard use like this. If you are using a Malkoff module in a Surefire weaponlight, you might want to re-consider before you break your 50+ dollar drop-in.
